주요 콘텐츠로 건너뛰기
MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement
필요한 것
  1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: 1 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: 1 단계, 이미지 2/2
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 2 단계, 이미지 1/1
    • Slide the battery cover off in the direction of the arrow on the cover.
  3. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 3 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 3 단계, 이미지 2/2
    • Remove the batteries (2 AA).
  4. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 5 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 5 단계, 이미지 2/2
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 6 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 6 단계, 이미지 2/2
    • Lift the metal tab until it is straight and can move through the slot in the battery compartment.
  7. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 7 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 7 단계, 이미지 2/2
    • Flip the remote controller to the external side and slide the metal connections in the battery compartment straight up.
    • Slide the new connections straight down into the slot in the battery compartment, flip to the internal side, and bend the metal tab until it's parallel with the battery compartment.
결론
Monica Reece
회원 가입일: 08/31/18
672 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 201
