주요 콘텐츠로 건너뛰기
MerchSource the Black Series Boat Racer Gaskets Replacement
필요한 것
  1. MerchSource the Black Series Boat Racer Gaskets Replacement, Gaskets: 1 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Gaskets Replacement, Gaskets: 1 단계, 이미지 2/2
    • Remove the screw on the top of the boat at the rear end using a Phillips #2 screwdriver.
    • Screw length is 16 mm.
  2. MerchSource the Black Series Boat Racer Gaskets Replacement: 2 단계, 이미지 1/3 MerchSource the Black Series Boat Racer Gaskets Replacement: 2 단계, 이미지 2/3 MerchSource the Black Series Boat Racer Gaskets Replacement: 2 단계, 이미지 3/3
    • Remove the top of the boat by sliding it backwards and then pulling it off.
  3. MerchSource the Black Series Boat Racer Gaskets Replacement: 3 단계, 이미지 1/2 MerchSource the Black Series Boat Racer Gaskets Replacement: 3 단계, 이미지 2/2
    • Grab the rubber gasket with tweezers and pull it out of the slot.
  4. MerchSource the Black Series Boat Racer Gaskets Replacement: 4 단계, 이미지 1/3 MerchSource the Black Series Boat Racer Gaskets Replacement: 4 단계, 이미지 2/3 MerchSource the Black Series Boat Racer Gaskets Replacement: 4 단계, 이미지 3/3
    • Gently remove the gasket and replace with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Monica Reece
회원 가입일: 08/31/18
672 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 262
