주요 콘텐츠로 건너뛰기
해당 분해도는 수리 안내서가 아닙니다. Power Bank 수리는 자사의 서비스 설명서를 사용하세요.
  1. Mi Wireless Power Bank Essential (WPB15ZM) disassembly, Opening: 1 단계, 이미지 3개 중 1개 Mi Wireless Power Bank Essential (WPB15ZM) disassembly, Opening: 1 단계, 이미지 3개 중 2개 Mi Wireless Power Bank Essential (WPB15ZM) disassembly, Opening: 1 단계, 이미지 3개 중 3개
    • There is really very much of tough glue on the sides, so you have to apply pretty much heat there, i personally used 3D printer bed, but heat gun should also work
    • The. you will have to insert a screwdriver or something thin and hard (eg old credit card) between the soft and hard plastic on top and pull it along the side to unstick the glue.
    • I don't think there is very much you can do then, so you will have to keep prying until the top cover comes down.
  2. Mi Wireless Power Bank Essential (WPB15ZM) disassembly, Removing the board and the battery: 2 단계, 이미지 2개 중 1개 Mi Wireless Power Bank Essential (WPB15ZM) disassembly, Removing the board and the battery: 2 단계, 이미지 2개 중 2개
    • First, remove the three screws from the board so you don't tear any wire when the battery comes out at once.
    • Next you will have to remove the battery, there are two glue tapes under it, so now you will have to heat the bottom and then try to pry the battery up.
    • Take caution about all the wires coming to the battery.
작성자
1다른 기여자 명과 함께
Vojtak42
회원 가입일: 10/24/24
88 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 66
전체 시간: 591
