주요 콘텐츠로 건너뛰기
Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement
필요한 것
  1. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the upper shell: 2 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the upper shell: 2 단계, 이미지 2개 중 2개
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 3 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the upper shell straight up off of the machine to remove it.
  4. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the right-side cover: 4 단계, 이미지 1개 중 1개
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 5 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 5 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 6 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 6 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Disconnect the ground wires: 7 단계, 이미지 1개 중 1개
    • Use a 5/16 inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
  8. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Disconnect the fuel line: 8 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Disconnect the fuel line: 8 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Disconnect the fuel line: 8 단계, 이미지 3개 중 3개
    • Use a pair of needle nose pliers to release the hose clamp from the fuel line.
    • Slide the hose clamp off of the nipple, about one inch down the fuel line.
  9. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 9 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Pull to disconnect the fuel line from the motor and pump assembly.
  10. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 10 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Use a pair of needle nose pliers to remove the fuel line hose clamp.
  11. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Disconnect the motor and pump assembly: 11 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Disconnect the motor and pump assembly: 11 단계, 이미지 2개 중 2개
    • Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
    • One red cable labeled MOTOR 2 on the main PCB board
    • One orange cable labeled MOTOR 1 on the main PCB board
    • Pull the wires with the needle nose pliers by their connectors and not the wires themselves.
  12. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 12 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 12 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Use a pair of flush cutters to cut the cable tie harnessing the wires running from the main PCB assembly.
    • Remove the cable tie.
    • During reassembly, install a new cable tie.
  13. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 13 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • Use a pair of flush cutters to cut the cable tie harnessing the orange, red, white, and black wires near the fuel line.
  14. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 14 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Use a pair of flush cutters to cut the cable tie harnessing the orange and red wires next to the motor.
  15. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Detach the capacitor: 15 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
  16. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 16 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 16 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the capacitor from the band clamp.
    • During reassembly, realign the foam padding between the capacitor and the band clamp.
  17. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the motor and pump assembly: 17 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the motor and pump assembly: 17 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the motor and pump assembly: 17 단계, 이미지 3개 중 3개
    • Feed the orange and red wires out through the opening in the lower shell.
  18. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 18 단계, 이미지 1개 중 1개
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the left-side cover.
  19. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 19 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 19 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 19 단계, 이미지 3개 중 3개
    • Remove the left-side cover.
  20. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 20 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 20 단계, 이미지 2개 중 2개
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four screws securing the motor mount bracket, two on each side.
  21. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 21 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 21 단계, 이미지 2개 중 2개
    • Lift the motor, pump, and bracket assembly straight up out of the machine.
  22. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the fan: 22 단계, 이미지 1개 중 1개
    • Use a 3 mm hex key to loosen the set screw securing the fan to the motor shaft.
    • The set screw does not need to be fully removed.
  23. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 23 단계, 이미지 2개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 23 단계, 이미지 2개 중 2개
    • Remove the fan.
  24. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement, Remove the motor mount bracket: 24 단계, 이미지 1개 중 1개
    • Use a 5/16 inch socket or Phillips screwdriver to remove the two screws securing the motor and pump assembly to the motor mount bracket.
  25. Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 25 단계, 이미지 3개 중 1개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 25 단계, 이미지 3개 중 2개 Mi-T-M Heater MH-0190-0M10 Motor and Pump Assembly Replacement: 25 단계, 이미지 3개 중 3개
    • Remove the motor mount bracket.
    • Only the motor and pump assembly remain.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
93,094 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 284
