소개
Use this guide to remove or replace the pressure regulator on a MiTM Air Compressor AM1HE0205HD 2014.
필요한 것
Ensure the compressor is unplugged.
Flip the pressure switch lever up to the off position.
Pull the ring on the safety release valve away from the compressor tank to drain the air from the compressor.
Use a 3/4 inch wrench to loosen and remove the air hose quick-connect socket.
Use a 5/8" wrench to loosen the air tank nipple from the air tank enough to be able to rotate it with the regulator.
거의 끝나갑니다!
결론
