주요 콘텐츠로 건너뛰기
MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement, Remove the belt guard bracket bolts: 1 단계, 이미지 1/1
    • Use a 7/16 inch socket to remove the nuts and accompanying bolts securing the belt guard bracket to the rear belt guard.
    • You may need to hold the bolts in place with a 7/16 inch wrench during removal.
    • Don't misplace the washers that are removed during this step.
    • During reassembly, you may need to slightly loosen the two head bolts securing the belt guard bracket in order to properly align the bracket with the mounting holes in the rear belt guard.
  2. MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement: 2 단계, 이미지 1/1
    • Use a 1/2 inch socket to remove the two bolts securing the belt guard bracket to the cylinder head.
    • Don't lose the loosened spacers underneath the belt guard bracket.
  3. MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement, Remove the belt guard bracket: 3 단계, 이미지 1/2 MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement, Remove the belt guard bracket: 3 단계, 이미지 2/2
    • Lift the belt guard bracket straight up to remove it.
  4. MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement, Remove the spacers: 4 단계, 이미지 1/2 MiTM Air Compressors AM1PH6508HD 2012 Belt Guard Bracket Replacement, Remove the spacers: 4 단계, 이미지 2/2
    • Remove the four spacers from the top of the cylinder head.
결론
Kyle Smith
회원 가입일: 02/01/21
40,780 평판
안내서 123개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 18
