주요 콘텐츠로 건너뛰기
MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement
필요한 것
  1. MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Disconnect all hoses and unplug the power cord: 1 단계, 이미지 2개 중 1개 MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Disconnect all hoses and unplug the power cord: 1 단계, 이미지 2개 중 2개
    • Disconnect all hoses and unplug the power cord before performing any repairs on the Mi-T-M electric pressure washer.
  2. MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Remove four hex bolts: 2 단계, 이미지 2개 중 1개 MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Remove four hex bolts: 2 단계, 이미지 2개 중 2개
    • Use a socket wrench to remove the four 47.9 mm-long 11 mm hex head bolts holding the motor in place from the bottom of the frame assembly.
    • Only remove these bolts while the pressure washer is in an upright position.
    • You will likely need an additional 11 mm wrench to hold the nuts on top of the stacks in place as you loosen the bolts.
  3. MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Remove zip ties: 3 단계, 이미지 2개 중 1개 MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Remove zip ties: 3 단계, 이미지 2개 중 2개
    • Remove the zip ties holding the power cord to the frame assembly.
    • During reassembly, replace these zip ties after you have bolted the motor in place to ensure there is enough slack between the frame and the electrical box.
  4. MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Remove the motor: 4 단계, 이미지 2개 중 1개 MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement, Remove the motor: 4 단계, 이미지 2개 중 2개
    • Remove the motor and pump assembly from the frame.
  5. MiTM Pressure Washer CM1400HDEC1 2017 Motor Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • If your replacement motor comes with pre-installed rubber isolator feet, remove the bolts in them before installing the new motor to the frame assembly.
    • You can re-install the motor with the new feet or the original ones, but only the original 11 mm hex head bolts from the frame assembly are long enough to safely secure the motor to the frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Taylor Dixon
회원 가입일: 06/26/18
71,789 평판
안내서 94개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 56
전체 시간: 2,479
