소개
Follow the steps in this guide to remove and replace the motor/pump assembly of a Mi-T-M CM1400HDEC1 electric pressure washer.
필요한 것
Use a socket wrench to remove the four 47.9 mm-long 11 mm hex head bolts holding the motor in place from the bottom of the frame assembly.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
