주요 콘텐츠로 건너뛰기
MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement
필요한 것
  1. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter bolts: 1 단계, 이미지 1/1
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Use a 10 mm socket to remove the three 24 mm long bolts.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter assembly: 2 단계, 이미지 1/1
    • Remove the recoil starter assembly.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: 3 단계, 이미지 1/2 MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: 3 단계, 이미지 2/2
    • If you are replacing the assembly with a non-OEM part, you may also have to replace the starter cap.
    • Remove the 3/4" bolt with a deep socket.
    • This bolt can be very difficult to remove. Use the hook as a bracing point to keep the starter cap from rotating.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,561 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,767개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 673
