주요 콘텐츠로 건너뛰기
Michael Kors Watch Link Band Replacement
필요한 것
  1. Michael Kors Watch Link Band Replacement, Link Band: 1 단계, 이미지 1/1
    • Place the watch on your wrist and determine whether links should be added or removed.
    • If watchband needs to be expanded, approximate the number of links required.
  2. Michael Kors Watch Link Band Replacement: 2 단계, 이미지 1/3 Michael Kors Watch Link Band Replacement: 2 단계, 이미지 2/3 Michael Kors Watch Link Band Replacement: 2 단계, 이미지 3/3
    • Set the watch on the block holder.
    • Ensure the arrows located on the links are pointing downward.
  3. Michael Kors Watch Link Band Replacement: 3 단계, 이미지 1/1
    • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
    • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
    • Two pins hold each link to the band, so two pins must be removed per link.
  4. Michael Kors Watch Link Band Replacement: 4 단계, 이미지 1/1
    • Discard the broken links or save any extra links that you remove.
  5. Michael Kors Watch Link Band Replacement: 5 단계, 이미지 1/2 Michael Kors Watch Link Band Replacement: 5 단계, 이미지 2/2
    • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
    • Insert pins into the holes that connect the new link to the rest of the watchband.
    • Use the soft side of the hammer to strike the pin down.
  6. Michael Kors Watch Link Band Replacement: 6 단계, 이미지 1/2 Michael Kors Watch Link Band Replacement: 6 단계, 이미지 2/2
    • Lastly, make sure that all the pins joining the links are secured in place.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jack Beinkampen
회원 가입일: 10/06/16
278 평판
안내서 1개 작성함
University of Memphis, Team 4-5, Baddour Fall 2016 University of Memphis, Team 4-5, Baddour Fall 2016 회원
UM-BADDOUR-F16S4G5
3 회원들
안내서 2개 작성하였습니다
댓글 9개
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - 답글
How can I puchace the first link on my Michael kors ceramic watch
melissa.costello31 -
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - 답글
Where can I get the white bands that cover the links on my my watch as a few have bits broken
Karenclemo@gmail.com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 68
30일 전: 247
전체 시간: 77,019
