소개
This guide will show you how to dissemble the microphone. Before you start you need to have a set of screw drivers (Philips head #00, #2, #0). To reassemble the microphone just reverse the steps.
For names of the microphone parts, please click below:
Microphone Parts' Manual
  1. Remove the windscreen. Using the Phillips head (#00) screwdriver, unscrew the diaphragm from the bottom base of the microphone.
    • Remove the windscreen. Using the Phillips head (#00) screwdriver, unscrew the diaphragm from the bottom base of the microphone.
  2. Separate the microphone into two pieces to reveal the internal shield cover. Separate the microphone into two pieces to reveal the internal shield cover.
    • Separate the microphone into two pieces to reveal the internal shield cover.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. By unscrewing in a clockwise motion remove the bottom base of the microphone. This should free up the bottom base so that it can be separated from the microphone.
    • By unscrewing in a clockwise motion remove the bottom base of the microphone.
    • This should free up the bottom base so that it can be separated from the microphone.
  5. Using the Phillips head (#2) screwdriver, remove screw directly above the battery by rotating counterclockwise.
    • Using the Phillips head (#2) screwdriver, remove screw directly above the battery by rotating counterclockwise.
  6. Using the Phillips head (#0) screwdriver to remove the black screw near the bottom of the microphone.
    • Using the Phillips head (#0) screwdriver to remove the black screw near the bottom of the microphone.
  7. Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible. Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible. Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible.
    • Use the heavy duty spudger to detach the grip area from the microphone. The inside of the diaphragm should now be visible.
결론
첨부 문서
Kefaya
회원 가입일: 2014년 01월 23일
343 평판
안내서 3개 작성하였습니다
New Mexico State, Team 1-2, Sheppard Spring 2014 New Mexico State, Team 1-2, Sheppard Spring 2014 회원
NMSU-SHEPPARD-S14S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 45
전체 시간: 3,375
