주요 콘텐츠로 건너뛰기
Microsoft Band 2 Battery Replacement
필요한 것
  1. Microsoft Band 2 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: 2 단계, 이미지 1/1
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: 4 단계, 이미지 1/2 Microsoft Band 2 Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: 5 단계, 이미지 1/2 Microsoft Band 2 Battery Replacement: 5 단계, 이미지 2/2
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: 6 단계, 이미지 1/2 Microsoft Band 2 Battery Replacement: 6 단계, 이미지 2/2
    • Pry out the battery using the plastic opening tool.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Chris Syracuse
회원 가입일: 02/20/17
639 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G5, Leahy Spring 2017 USF Tampa, Team S1-G5, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G5
3 회원들
안내서 5개 작성하였습니다
댓글 14개
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - 답글
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - 답글
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - 답글
The only place i found was ebay:
ftlay - 답글
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 33
전체 시간: 12,859
