소개
This guide will cover how to remove the screen of the Microsoft Band 2 smartwatch. If the display is blank or dim it may be advantageous to consider replacing the screen on the Band 2.
필요한 것
Use a heatgun to melt the adhesive beneath the screen. Heat the metal around edges of the screen.
이 단계에 사용된 도구:Spudger$2.99
Use a spudger and plastic opening picks to pry the screen away from the Band 2.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
Way too Late lol.
