주요 콘텐츠로 건너뛰기
Microsoft Band 2 defective battery connection/ribbon Replacement
필요한 것
  1. Microsoft Band 2 defective battery connection/ribbon Replacement, defective battery connection/ribbon: 1 단계, 이미지 1/3 Microsoft Band 2 defective battery connection/ribbon Replacement, defective battery connection/ribbon: 1 단계, 이미지 2/3 Microsoft Band 2 defective battery connection/ribbon Replacement, defective battery connection/ribbon: 1 단계, 이미지 3/3
    • Carve away *almost* all of the rubber of the straps. (Leave the rubber surrounding the battery/heart rate clasp end.)
  2. Microsoft Band 2 defective battery connection/ribbon Replacement: 2 단계, 이미지 1/3 Microsoft Band 2 defective battery connection/ribbon Replacement: 2 단계, 이미지 2/3 Microsoft Band 2 defective battery connection/ribbon Replacement: 2 단계, 이미지 3/3
    • Partly dissassemble the battery clasp end: pry up the silver clasp face that is taped down, unscrew the four T3 Torx , remove that cover, remove the battery
  3. Microsoft Band 2 defective battery connection/ribbon Replacement: 3 단계, 이미지 1/2 Microsoft Band 2 defective battery connection/ribbon Replacement: 3 단계, 이미지 2/2
    • Remove the plastic 'sandwiching' the ribbon as it travels into the clasp end, with a Dremel or knife. (Picture 2 illustrates the removed plastic.)
  4. Microsoft Band 2 defective battery connection/ribbon Replacement: 4 단계, 이미지 1/2 Microsoft Band 2 defective battery connection/ribbon Replacement: 4 단계, 이미지 2/2
    • Sand the ribbon to expose the conductors on both sides. Be careful to keep the insulator in between the two conductors intact, so they don't short. The second picture shows a 10x image of the layers of copper and insulator.
  5. Microsoft Band 2 defective battery connection/ribbon Replacement: 5 단계, 이미지 1/3 Microsoft Band 2 defective battery connection/ribbon Replacement: 5 단계, 이미지 2/3 Microsoft Band 2 defective battery connection/ribbon Replacement: 5 단계, 이미지 3/3
    • Wrap the repaired break with insulating tape. Sand away outer insulator on both sides to make soldering locations for jumper strips.
  6. Microsoft Band 2 defective battery connection/ribbon Replacement: 6 단계, 이미지 1/1
    • Use Sugru to wrap/stabilize the repair and integrate it into the clasp end's rubber.
  7. Microsoft Band 2 defective battery connection/ribbon Replacement: 7 단계, 이미지 1/1
    • Drill two holes into clasp-end plastic tabs, and two holes on each side of watch face's 'shoulders', as anchor points for thread to fasten strap leather. (Hole locations are the black dots on the gold metal near the silver casing.)
  8. Microsoft Band 2 defective battery connection/ribbon Replacement: 8 단계, 이미지 1/3 Microsoft Band 2 defective battery connection/ribbon Replacement: 8 단계, 이미지 2/3 Microsoft Band 2 defective battery connection/ribbon Replacement: 8 단계, 이미지 3/3
    • Build new leather straps; fasten using thread through holes & glue.
결론
Your Rand 2 should (!) hold a charge now. Not sure how durable this repair is.
다른 2명이 해당 안내서를 완성하였습니다.
Kirk McDermid
회원 가입일: 08/20/17
171 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,272
