주요 콘텐츠로 건너뛰기
Microsoft Kinect LED Replacement
필요한 것
  1. Microsoft Kinect LED Replacement, Case: 1 단계, 이미지 1/3 Microsoft Kinect LED Replacement, Case: 1 단계, 이미지 2/3 Microsoft Kinect LED Replacement, Case: 1 단계, 이미지 3/3
    • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
    • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
    • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
    • Do not overheat as it may cause damage to the internal components.
  2. Microsoft Kinect LED Replacement: 2 단계, 이미지 1/1
    • Unscrew the six 12mm T10 Torx screws.
  3. Microsoft Kinect LED Replacement: 3 단계, 이미지 1/3 Microsoft Kinect LED Replacement: 3 단계, 이미지 2/3 Microsoft Kinect LED Replacement: 3 단계, 이미지 3/3
    • Remove the top portion of the case from the rest of the body.
    • Detach the side portions of the case from the body.
    • Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
    • When unplugging the fan, be sure to pull from the white connector at the end of the wire to avoid breaking it.
  4. Microsoft Kinect LED Replacement: 4 단계, 이미지 1/1
    • Remove the bottom portion of the case by sliding it out from under the body.
    • The bottom of the case may be difficult to remove if there is any residual adhesive. If the residual adhesive prevents you from removing the case, apply gentle heat and wiggle the case out.
  5. Microsoft Kinect LED Replacement: 5 단계, 이미지 1/2 Microsoft Kinect LED Replacement: 5 단계, 이미지 2/2
    • Remove the four 7mm T10 Torx screws (two on each side of the metal body).
  6. Microsoft Kinect LED Replacement: 6 단계, 이미지 1/2 Microsoft Kinect LED Replacement: 6 단계, 이미지 2/2
    • Remove the front portion of the case containing the lens coverings for the cameras.
    • The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
  7. Microsoft Kinect LED Replacement, Microphone Panel: 7 단계, 이미지 1/1
    • Unplug the microphone from motherboard.
  8. Microsoft Kinect LED Replacement: 8 단계, 이미지 1/1
    • Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
    • Pull the cable out carefully to avoid damage.
  9. Microsoft Kinect LED Replacement, Motherboard: 9 단계, 이미지 1/1
    • Unscrew the seven 6.5mm T10 Torx screws.
  10. Microsoft Kinect LED Replacement: 10 단계, 이미지 1/1
    • Disconnect the bridge connecting the first and second layer of the motherboard.
    • Pull the first layer of the motherboard off.
  11. Microsoft Kinect LED Replacement: 11 단계, 이미지 1/1
    • Unplug the LED cable from the motherboard.
  12. Microsoft Kinect LED Replacement: 12 단계, 이미지 1/1
    • Unscrew the three 16.5mm screws using the 5mm Nut Driver.
    • Unscrew the one 6.5mm T10 Torx screw.
  13. Microsoft Kinect LED Replacement: 13 단계, 이미지 1/2 Microsoft Kinect LED Replacement: 13 단계, 이미지 2/2
    • Remove the three ribbon cables.
    • Disconnect the left most camera from the motherboard.
  14. Microsoft Kinect LED Replacement, LED: 14 단계, 이미지 1/1
    • Gently pull the LED out of the front of the metal casing. It should slide out easily.
결론
Nick Carlucci
회원 가입일: 04/26/15
394 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-7, Amido Spring 2015 Cal Poly, Team 14-7, Amido Spring 2015 회원
CPSU-AMIDO-S15S14G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 589
