주요 콘텐츠로 건너뛰기
Microsoft Lumia 435 LCD Display Replacement
필요한 것
동영상 개요
  1. Microsoft Lumia 435 LCD Display Replacement, Back Cover: 1 단계, 이미지 1/3 Microsoft Lumia 435 LCD Display Replacement, Back Cover: 1 단계, 이미지 2/3 Microsoft Lumia 435 LCD Display Replacement, Back Cover: 1 단계, 이미지 3/3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 LCD Display Replacement: 2 단계, 이미지 1/3 Microsoft Lumia 435 LCD Display Replacement: 2 단계, 이미지 2/3 Microsoft Lumia 435 LCD Display Replacement: 2 단계, 이미지 3/3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 LCD Display Replacement, Logic board: 3 단계, 이미지 1/3 Microsoft Lumia 435 LCD Display Replacement, Logic board: 3 단계, 이미지 2/3 Microsoft Lumia 435 LCD Display Replacement, Logic board: 3 단계, 이미지 3/3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 LCD Display Replacement: 4 단계, 이미지 1/2 Microsoft Lumia 435 LCD Display Replacement: 4 단계, 이미지 2/2
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 LCD Display Replacement, LCD Display: 5 단계, 이미지 1/3 Microsoft Lumia 435 LCD Display Replacement, LCD Display: 5 단계, 이미지 2/3 Microsoft Lumia 435 LCD Display Replacement, LCD Display: 5 단계, 이미지 3/3
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 LCD Display Replacement: 6 단계, 이미지 1/3 Microsoft Lumia 435 LCD Display Replacement: 6 단계, 이미지 2/3 Microsoft Lumia 435 LCD Display Replacement: 6 단계, 이미지 3/3
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 LCD Display Replacement: 7 단계, 이미지 1/1
    • The display is very fragile, do the separation very carefully.
결론
다른 5명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,182 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 2개
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - 답글
I am pretty sure he didn’t use ifixit stuff to fix the screen, lmao
mario rados - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 3,219
