주요 콘텐츠로 건너뛰기
Microsoft Lumia 435 Touch screen Glass Only Replacement
필요한 것
동영상 개요
  1. Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: 1 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: 1 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: 1 단계, 이미지 3/3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 Touch screen Glass Only Replacement: 2 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 2 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 2 단계, 이미지 3/3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: 3 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: 3 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: 3 단계, 이미지 3/3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 Touch screen Glass Only Replacement: 4 단계, 이미지 1/2 Microsoft Lumia 435 Touch screen Glass Only Replacement: 4 단계, 이미지 2/2
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: 5 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: 5 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: 5 단계, 이미지 3/3
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 Touch screen Glass Only Replacement: 6 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 6 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 6 단계, 이미지 3/3
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 Touch screen Glass Only Replacement: 7 단계, 이미지 1/1
    • The display is very fragile, do the separation very carefully.
  8. Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: 8 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: 8 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: 8 단계, 이미지 3/3
    • Put some transparent scotch tape to prevent the glass from shattering.
    • Warm the glass for a minute to make adhesive soften.
    • Start the separation from the middle of the frame, where the contact area is smaller.
  9. Microsoft Lumia 435 Touch screen Glass Only Replacement: 9 단계, 이미지 1/3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 9 단계, 이미지 2/3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 9 단계, 이미지 3/3
    • When you finished with the separation the glass, clean the frame from the old adhesive.
    • Install the new touch screen and start to reassemble the device.
  10. Microsoft Lumia 435 Touch screen Glass Only Replacement: 10 단계, 이미지 1/1
    • That's all.
결론
다른 5명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
192,056 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 한 개
Is the lcd adhesive just on the edges of the lcd or covering the entire thing?
Addison Ramsey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 5,301
