주요 콘텐츠로 건너뛰기
Microsoft Lumia 535 - Factory Reset, Screen Lock Removal
동영상 개요
  1. Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: 1 단계, 이미지 1/3 Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: 1 단계, 이미지 2/3 Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: 1 단계, 이미지 3/3
    • Switch off the phone.
    • Press and hold the Volume Down button and connect your charger. When you see an exclamation mark release the button.
    • Now press the keys in this sequence:
    • Volume Up
    • Volume Down
    • Power
    • Volume Down
    • The phone will reset and reboots.
결론
Your device is now reset!
다른 193명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,055 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,506개 작성하였습니다
댓글 112개
thanks a lot!!
very useful!
suchitra kumar - 답글
You are mouthed
Idris - 답글
THankx for your help..
Pinak - 답글
but my mobile timeing was 107 and this step are not work that
shahaji jadhav - 답글
same with me.
can you help me? I try the step but is not work in my mobile timing is 790880. how to remove those screen password?
Alden Hammisain -
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 41
30일 전: 209
전체 시간: 388,222
