소개
• Hard Reset / Factory Reset / Master Reset: Delete all customer data (phone book, downloads, accounts, etc.) remove all installed apps and restore the phone to its factory state.
• This will help you if you forgot your Screen Password Lock, PIN or if you have a problem with the OS or installed app.
동영상 개요
Switch off the phone.
Press and hold the Volume Down button and connect your charger. When you see an exclamation mark release the button.
Now press the keys in this sequence:
Volume Up
Volume Down
Power
Volume Down
The phone will reset and reboots.
Your device is now reset!
다른 189명이 해당 안내서를 완성하였습니다.
댓글 110개
thanks a lot!!
very useful!
but my mobile timeing was 107 and this step are not work that
same with me.
can you help me? I try the step but is not work in my mobile timing is 790880. how to remove those screen password?
It really worked for my Microsoft Lumia 535. Thanks
how did you do it because mine turning on as soon as l press the volume up button
Thanks A lot. Saved my day
When i press that button nothing happen to the phone it only starts..
When i press that button the phone starts and nothing happen
did your work out
thanks, worked for me
when I followed what you have stated, my phone could not load up the exclamation mark but shows battery charging sign
Answer to skipping ! Symbol and going straight to battery charging symbol?
Good Way Thankx.......
It worked greatly thank you very much it is greatly greatly appreciated it was just as simple as it is explained!!!
worked for me thanks man.
i followed the same instructions, but when I press the start button my phone switches on and goes back to the password locked screen.
Thats what mine is doing did u find a solution
Thank you...saved my time
Não resultou... Fica em loop mostrando as engrenagens e depois uma carinha triste
Que posso fazer para voltar a ligar o telemóvel??
You knw Actually the lock has been broken but i duano what is next step mean while it's asking to fix some point for which look forward to get this done.
%#*@ it actually worked
Alex Teano - 답글
thank you bro........
very useful guide
Thanks for your very good information
b17karthik - 답글
did we lost win 10 switch back to win 8.1 from win10 after factory reset?
my lumia 535 face screen freeze and some time auto power off and power button not working problem
when I press power button it show dim light and black screen again and also got heat up from upper front back side
the only thing work in these issue is remove back cover put off battery put in again
Very Useful.........
Genius and bravo
The author did an excellent job that deserves commendation.The steps were so easy and straight forward
good on ya mate thanks for trick
thank you very much
please help, I just did the hard reset but now it's denying my microsoft account login...
i did the reset but failing to login my account and now I cant do anything. Im stuck on the sign in page..
It works for me lumia 540 thanks a lot....for your valuable suggestion..
Thanks a lot it really work for me......kudos
I try it but it really really and extremely work for me thanks a lot
awesome it really works. thanks alot
My phone appears (try again in 1034387 minutes) and could not open. Please help me. URGENT
Thaaaaaank Youuuuuu soooo mucccchhh
This process is fully working if Your touch is Not working
It's like a GTA cheat code from the ps2 days, btw it worked for me :<}
Thanks It worked
lasherrika - 답글
It worked thank ya vry much amigo
thanks alot it helped.
Bohat bohat shukriya
thank you sooooooooooooooooooooooooooooooooo much
can I do that on my phone but it has no power
please help, can I do that on a powerless phone
It is working but after reset edge browser is missing old help me
Cool! Other remember to remove you sceenlock first before trying this, then it will work/
how much time it should take to reboot and start
Whats the answer to the timeframe regaurding how long does it take fof the reset to take?
Whats the eta for reset
Thanks to the author, for his excellent work.
Thanks to the author for his excellent work.
Not working for me. Pls help to reset password.
This method Not working for me. Phone only starts. Pls help me.
Thanks…..very helpful
My mircosoft windows phone will not factory reset
You are really genious bro… Awesome…
Thanks and it works for me very nicely…
You are a guru, genius, in fact Einstein….. thanks a lot
Cheers man…it worked. God bless
Thanks alot!
If it failed for you try it this way without the charger: Press the power button to start and when it vibrates hold the volume down button until it shows you the exclamation mark. the do the volume up down power down sequence mentioned above here and leave it aside to show the logo then spinning cog wheels. The charge route failed for me too till i found the route where you dont include the charger.
My didnt work at all
The reset worked but it is asking for a reset protection recovery key that I am not able to get
Thank you vry vry much…
Wow it works
it’s working.. although we have it trial and error, and thank to you…
Thank so much it really work perfectly for me
phone restarts when i hold volume down
can’t reset
Very useful & easy
you are good lumia, great job done
thanks bhai success
thank you. my friend lost her phone so she’s going to use her previous phone and ask me to do a hard reset. great help dude!
Very easy, very useful
sandyinkx3 - 답글
Omg….Your my HERO! :-)
HI Team,
My phones touch is not working since last night…please help
mine is refusing to go to the main menu
what should i do
you can also reset your lumia by going into settings, scroll down and chose about phone in there it gives you the option to reset phone click on and you will be prompted are you sure press OK and it will shut down and when it restarts it will show 2 cogs turning this take about 2/3 minutes, you now have your phone back to factory set. hope this helps those who could not do it the other way?
It’s been 1 hour and the wheels are still rotating. What should i do? :( :( :( :(
Thank you
Thank you
great help. now i can use my phone again . i love the feathers but soon it will be dead as microsoft unable to tap the market potential of windows phones any more
Thanks a Lot
super reset method of mobile .
Dattaraj Naik- 10-09-2019
Wow!! It really worked like a charm.. thanks for sharing this
Ricky Ross - 답글
Volume up button not working…. Any other way of reset my phone???
Raja 12345 - 답글
Done this but the former owner had the reset protection on and now it wants the recovery key
While the update is underway, the outbreak has come to an end. Then a mark comes up on a display
Thank you this was extremely easy . I have this as a back up phone . I dropped my Galaxy S10e and destroyed the screen I had forgotten the pin lock on this one and needed a fully operable phone for the next few days while I wait on my replacement from the insurance.
Sanity is restored
When exclamation mark appears and i press Volume Up button. exclamation mark disappears before even I press volume down button
मेरे फोन में इस गतिविधि से चरखा सा चलने लगा
Thanks buddy:)
Akabri Dhaval - 답글
Please help me i have problem resrting my phone..
kier jumento - 답글
Are you really?
eyobe - 답글
what a great Method .it work ........... thankx for genius method
usmanmanga85 - 답글
i did the reset but failing to login my account and now I cant do anything. Im stuck on the sign in page...
Chido Marufu -
i did reset but now cant login and cant access anything...
Chido Marufu -
Chido Marufu -
my phone cant touch anymore i hve microsoft mobile rm-1089.after hard reset the phone reboot and stuck at language selection no touch at all been hard resetting over and over. .any help?
bedelfever - 답글
bhai mayra nhi ho rha
ns890157 - 답글
it worked thnks ilove the tips
dex vin - 답글
Approximately how much time is it supposed to take?
Aashka Vora - 답글
This not working what else can I do?
Oluwakemi - 답글
Thank you so much you r great. I have done.....thanks
Rakshit - 답글
fantastic.Thank you so much
Kirti Sethia - 답글
fantastic.Thank you
Kirti Sethia - 답글
Awesome…Thank You so much…
Bipin Bihari Sethi - 답글
After I press the volume down key and insert my charger no exclamation mark appears so what do I do??
Richard Donkor - 답글
I am re start the phone as per instructions but the phone will not be open.
Still the exclamation mark appears
What I do?
Siva ganesh - 답글
total sucess
CPI - 답글
I followed the hard reset procedure, but when I press the volume up button, the phone goes off. I have not had the chance of pressing the other buttons. Please help me if there's any other method. Thanks
Lawrence Kumah - 답글
Very well... Thank you...
Ankita Kar - 답글
How do i cancel the hard reset?
Yadira Ruiz - 답글
Smash it! Hard on the ground. Quick.
Edgar Cintron -
Thanks exellent!
sunethwbs - 답글
resetting in progress. Thanks
Benjamin Bara - 답글
wa za mara da kho mata yada wa
niamatullah123 - 답글
Thanks dude ! :*
Danujaya Rathnayake ツ - 답글
good and easy mode.
thanks a lot
MAHAM NAZIR - 답글
I did reset but my restoration code isn't received. Same phone number and email address but still have not been able to receive code. Please help. How will I receive code. I'm checking my email for code. No text message received yet.
Arabi - 답글
It really worked. Thanks for the post
braphord saunders oliver - 답글
Thanks it works and make sense
HAMMED ALAGBE - 답글
Thank a lot, its working.
P Gana - 답글
Volume up button is not working…. Any other way of reset my phone??
Raja 12345 - 답글
I can’t install any app on my windows phone
Chaudary Ibrar - 답글
I did get the exclamation point symbol but now it has more of a lighting bolt w the settings symbol. Can't do anything to it now? Please reply. I appreciate the help so far.
miranda hackford - 답글
Has anyone recieved any reply back?
You sir are a beast.. Beautiful.. It work for me.. Thanks! Edgar lynn ma..✌
Edgar Cintron - 답글
Thanks. It worked
Atul Chawathe - 답글
