주요 콘텐츠로 건너뛰기
Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement
필요한 것
동영상 개요
  1. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Back Cover / Rear Case: 1 단계, 이미지 2개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Back Cover / Rear Case: 1 단계, 이미지 2개 중 2개
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 2 단계, 이미지 2개 중 2개
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 3 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 3 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 3 단계, 이미지 3개 중 3개
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Logic board: 4 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Logic board: 4 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Logic board: 4 단계, 이미지 3개 중 3개
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 5 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 5 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 5 단계, 이미지 3개 중 3개
    • Insert wisdom here.
  6. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Touch Screen Glass, LCD Display: 6 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Touch Screen Glass, LCD Display: 6 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Touch Screen Glass, LCD Display: 6 단계, 이미지 3개 중 3개
    • Remove the display flex cable rubber.
    • Put scotch tape on glass to prevent it from shattering.
    • Use a hair dryer or heat gun and warm the glass to make adhesive soft.
  7. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 7 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 7 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 7 단계, 이미지 3개 중 3개
    • Use a cutter or other tool with a sharp edge and start the separating from the bottom side. When you make enough room, continue the operation with a plastic tool.
    • Work slowly and do not force the frame with the display too much.
    • If necessary, warm again the glass with a hairdryer.
  8. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 8 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 8 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 8 단계, 이미지 3개 중 3개
    • Using a plastic tool, carefully remove the display.
    • Clean the frame from the remainders of the old adhesive.
  9. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 9 단계, 이미지 3개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 9 단계, 이미지 3개 중 2개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 9 단계, 이미지 3개 중 3개
    • Install back the display.
    • Put adhesive tape 2mm on the digitizer.
    • Order the digitizer glass together with an adhesive tape. The replacement is easier.
  10. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 10 단계, 이미지 2개 중 1개 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: 10 단계, 이미지 2개 중 2개
    • Install the touch screen and start with the reassembling.
    • That's all.
    • Did you do it successfully?
결론
다른 50명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,865 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,451개를 작성함
19가이드 댓글
hi
cane you tell me price of out glass of lumia 535 duol sim please ?!
omarkhalil - 답글
2mm adhesive tape means thickness
Jithu - 답글
Also does touch come out if we put adhesive tape.
Jithu - 답글
I want to join in your team
Saikrishna - 답글
Hi,How to know which the versions touch screens my phone is Lumia 535 RM-1089 , please?
priscilaalmerinda - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 102
전체 시간: 112,474
