주요 콘텐츠로 건너뛰기
Microsoft Lumia 640 LTE Front Screen Replacement
필요한 것
  1. Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 1 단계, 이미지 1/3 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 1 단계, 이미지 2/3 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 1 단계, 이미지 3/3
    • Back comes apart easily
  2. Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: 2 단계, 이미지 1/2 Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: 2 단계, 이미지 2/2
    • Peel the tape from left to the right.
    • Under the tape there is a hidden screw.
  3. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the back screws.: 3 단계, 이미지 1/1
    • Take these screws out, and remember organize your screws so you know where they are going when you are putting the phone back together.
  4. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the side screws.: 4 단계, 이미지 1/1
    • Turn the phone on its side and there are two (2) more screws that needs to be taken out.
  5. Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 5 단계, 이미지 1/3 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 5 단계, 이미지 2/3 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 5 단계, 이미지 3/3
    • Be careful of the top left corner of the phone, the connecting cable is sitting there.
    • The green arrows indicates where the cable is, so be careful
  6. Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: 6 단계, 이미지 1/2 Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: 6 단계, 이미지 2/2
    • disconnect the two connectors here: Green, and Red.
  7. Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 7 단계, 이미지 1/3 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 7 단계, 이미지 2/3 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 7 단계, 이미지 3/3
    • Carefully remove the cable.
    • Top two arrows indicate Camera, and chip. Button arrow indicate the way it is easiest to get the cable off.
  8. Microsoft Lumia 640 LTE Front Screen Replacement, Last step, remove the speaker.: 8 단계, 이미지 1/1
    • The speaker comes out really easy
    • Do not fear, it is not attached by a cable but only glue.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Nick Johansen
회원 가입일: 10/09/15
1,991 평판
안내서 2개 작성하였습니다
댓글 18개
Guys your awesome. I just replaced a cracked screen and it only cost me the price of a new one.
Ron Hudson - 답글
I'm happy to help, please let me know if there was any step that was hard to understand.
Nick Johansen - 답글
Hi guys microsoft lumia 640 front screen cracked where can i have it replaced plz
Delmark Lawrence - 답글
With the ease of replacing these screens and the availability of the part you could attempt it yourself as it is a simple process and a very rewarding one at that!! :) :p
Cory Hibbin -
thanks nick, do you have a picture of the device without speaker and ready to reassembling?
Labartsara Sara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 26,225
