소개
This repair is very easy and will only take 25-45 minutes.
필요한 것
Peel the tape from left to the right.
Under the tape there is a hidden screw.
Turn the phone on its side and there are two (2) more screws that needs to be taken out.
Be careful of the top left corner of the phone, the connecting cable is sitting there.
disconnect the two connectors here: Green, and Red.
Top two arrows indicate Camera, and chip. Button arrow indicate the way it is easiest to get the cable off.
다른 28명이 해당 안내서를 완성하였습니다.
댓글 18개
Guys your awesome. I just replaced a cracked screen and it only cost me the price of a new one.
Ron Hudson - 답글
I'm happy to help, please let me know if there was any step that was hard to understand.
Hi guys microsoft lumia 640 front screen cracked where can i have it replaced plz
With the ease of replacing these screens and the availability of the part you could attempt it yourself as it is a simple process and a very rewarding one at that!! :) :p
thanks nick, do you have a picture of the device without speaker and ready to reassembling?
Sorry for the slow resonse, I can try look around and see, however the speaker can easily come out and in. I mean it des not have to be there, it just sit there with glue
Ok. Ho iniziato ora devo continuare
you stopped short of showing me how to replace a new screen!
Do the steps in reverse :)
Excelente
I would love to say I. can replace the shattered glass screen on my Lumia 640 phone, but can't. Don't want to purchase another, love my phone. Question! Where can I take it to get it fixed? It's a must! Susan thanks for any info
papadoulis - 답글
do we need to buy the digitizer or simply the glass when the glass is broken and the phone is totally dizzy. only graphics are coming , no letters / visual in the screen
this is the worlds most easy est phone to ripar
Great instructions and a great design from Nokia. It only took 25 minutes.
Hi all, thanks for the very helpful instructions. I have one question about my phone though, which is that the glass screen is broken but the digitizer and LCD display are both fine. I’m planning on only buying the glass screen and digitizer combination as I know the LCD display will cost more. My question therefore is whether the LCD display is glued permanently onto the digitizer and glass screen? If it is, this would defeat the point of buying the digitizer and glass screen combination, and I’d have to opt for the triplet of LCD screen, digitizer, and glass screen. I can’t find any sources of information around on the net, and would really appreciate everyone’s kind help and thoughtful advice. Please kindly help, thank you so much!!! :)
Hi, I did the procedure. To complicate things this screen did not come with a midframe requiring removal of all the broken glass and glue. 2 part seems to work if applied very thin, use the 30 minute sort if you can’t get the right adhesive strips. Obviously don’t get it on the camera/front sensor assembly or screen connector!!
