주요 콘텐츠로 건너뛰기
Microsoft Lumia 640 XL Rear Facing Camera Replacement
필요한 것
  1. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Battery: 1 단계, 이미지 1/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Battery: 1 단계, 이미지 2/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Rear Facing Camera Replacement: 2 단계, 이미지 1/2 Microsoft Lumia 640 XL Rear Facing Camera Replacement: 2 단계, 이미지 2/2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Headphone Jack: 3 단계, 이미지 1/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Headphone Jack: 3 단계, 이미지 2/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Headphone Jack: 3 단계, 이미지 3/3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Rear Facing Camera Replacement: 4 단계, 이미지 1/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: 4 단계, 이미지 2/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: 4 단계, 이미지 3/3
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Motherboard: 5 단계, 이미지 1/2 Microsoft Lumia 640 XL Rear Facing Camera Replacement, Motherboard: 5 단계, 이미지 2/2
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Rear Facing Camera Replacement: 6 단계, 이미지 1/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: 6 단계, 이미지 2/3 Microsoft Lumia 640 XL Rear Facing Camera Replacement: 6 단계, 이미지 3/3
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
  7. Microsoft Lumia 640 XL Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 1/1
    • Disconnect the rear facing camera from the motherboard with tweezers.
결론
Madelyn Kolterman
회원 가입일: 10/17/18
507 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 151
