주요 콘텐츠로 건너뛰기
Microsoft Natural Multimedia Keyboard disassembly and cleaning
필요한 것
  1. Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: 1 단계, 이미지 1/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: 1 단계, 이미지 2/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: 1 단계, 이미지 3/3
    • A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
    • You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
  2. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 2 단계, 이미지 1/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 2 단계, 이미지 2/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 2 단계, 이미지 3/3
    • Use the flat end of a spudger to pop the keys off the keyboard.
  3. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 3 단계, 이미지 1/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 3 단계, 이미지 2/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 3 단계, 이미지 3/3
    • Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
    • Continue removing keys.
  4. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 4 단계, 이미지 1/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 4 단계, 이미지 2/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 4 단계, 이미지 3/3
    • Remove the 10 screws from the bottom of the keyboard.
    • Remove the upper button assembly.
  5. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 5 단계, 이미지 1/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 5 단계, 이미지 2/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 5 단계, 이미지 3/3
    • Use the tip of a spudger to push the upper button assembly buttons out from the back.
  6. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 6 단계, 이미지 1/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 6 단계, 이미지 2/3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 6 단계, 이미지 3/3
    • Remove the flexible keypad from the key caddy assembly.
    • The key caddies can be washed in the sink.
  7. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 7 단계, 이미지 1/1
    • The keys can also be washed.
    • Remove the metal retaining clips before washing to prevent rust.
결론
다른 9명이 해당 안내서를 완성하였습니다.
asvnix
회원 가입일: 11/18/12
274 평판
안내서 1개 작성함
댓글 3개
Thank you so much! I had never done this before and was very confused by the retaining bar.
Des Blackoak - 답글
I’ve had this keyboard since it was released and it just recently started having key sticking issues, so I opted to follow this guide and was pleasantly surprised at how well it worked. Thank you for this and I hope to get another 15 years out of it.
Suggestions:
1) Instead of manually cleaning, put the keys into a clear mesh bag and into the dish washer or washing machine.
2) Spray metal retainer bars with WD-40 and wipe off to help further prevent rust.
3) Let the keys and caddies sun dry for the day to ensure they do not retain any water after cleaning.
Thomas K - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 22
30일 전: 69
전체 시간: 12,957
