주요 콘텐츠로 건너뛰기
Microsoft Surface 2 I/O Cable Replacement
필요한 것
  1. Microsoft Surface 2  I/O Cable Replacement, Screen: 1 단계, 이미지 3개 중 1개 Microsoft Surface 2  I/O Cable Replacement, Screen: 1 단계, 이미지 3개 중 2개 Microsoft Surface 2  I/O Cable Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
  2. Microsoft Surface 2  I/O Cable Replacement: 2 단계, 이미지 3개 중 1개 Microsoft Surface 2  I/O Cable Replacement: 2 단계, 이미지 3개 중 2개 Microsoft Surface 2  I/O Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
  3. Microsoft Surface 2  I/O Cable Replacement, I/O Cable: 3 단계, 이미지 2개 중 1개 Microsoft Surface 2  I/O Cable Replacement, I/O Cable: 3 단계, 이미지 2개 중 2개
    • Work close to Magnetic Project Map to avoid losing screws.
    • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
    • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
    • Once all screws have been removed, lift and remove the bezel from the rest of the device.
  4. Microsoft Surface 2  I/O Cable Replacement: 4 단계, 이미지 2개 중 1개 Microsoft Surface 2  I/O Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two 2.19 mm T3 screws that hold down the SD card ribbon cable.
    • Remove the two 3.27 mm T3 screws holding down the charging port.
  5. Microsoft Surface 2  I/O Cable Replacement: 5 단계, 이미지 3개 중 1개 Microsoft Surface 2  I/O Cable Replacement: 5 단계, 이미지 3개 중 2개 Microsoft Surface 2  I/O Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to pry up the retaining plate at the end of the ribbon cable.
    • The retaining chip may be glued to the motherboard.
    • Use the spudger to flip up the small retaining flap on the cable's zero insertion force connector.
    • Make sure you are prying up on the retaining flap, not the connector itself.
    • Remove the ribbon cable from its port.
    • No force is needed to plug in or remove the ribbon cable.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Gregory Miller
회원 가입일: 02/04/16
415 평판
안내서 1개를 작성함
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G1
4 회원들
안내서 5개를 작성함
2가이드 댓글
I want to replace the battery of Microsoft Surface 2, which steps I have to follow to replace it?
Piero Sabino - 답글
Cosa devo utilizzare per attaccare il cavo del display sotto al fermaglio di distanza, colla o nastro biadesivo?
Piero Sabino - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 34
전체 시간: 4,799
