주요 콘텐츠로 건너뛰기
Microsoft Surface 2 Speaker Replacement
필요한 것
  1. Microsoft Surface 2 Speaker Replacement, Screen: 1 단계, 이미지 3개 중 1개 Microsoft Surface 2 Speaker Replacement, Screen: 1 단계, 이미지 3개 중 2개 Microsoft Surface 2 Speaker Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
  2. Microsoft Surface 2 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Microsoft Surface 2 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Microsoft Surface 2 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
  3. Microsoft Surface 2 Speaker Replacement, Speaker: 3 단계, 이미지 2개 중 1개 Microsoft Surface 2 Speaker Replacement, Speaker: 3 단계, 이미지 2개 중 2개
    • Work close to Magnetic Project Map to avoid losing screws.
    • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
    • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
    • Once all screws have been removed, lift and remove the bezel from the rest of the device.
  4. Microsoft Surface 2 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Using a T3 screwdriver, unscrew and remove the 3.5mm screws holding down the silver plates located at the corners of the device.
  5. Microsoft Surface 2 Speaker Replacement: 5 단계, 이미지 2개 중 1개 Microsoft Surface 2 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the cable connecting the speaker to the motherboard.
    • Peel up the tiny strip of yellow tape securing the cable to the motherboard.
  6. Microsoft Surface 2 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Microsoft Surface 2 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Lifting from the inmost end of the speaker, use a spudger to carefully pry the speaker from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
EG1
회원 가입일: 02/04/16
612 평판
안내서 2개를 작성함
USF Tampa, Team 3-1, Wollert Spring 2016 USF Tampa, Team 3-1, Wollert Spring 2016 회원
USFT-WOLLERT-S16S3G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 1,520
