주요 콘텐츠로 건너뛰기
단지 전제 조건
단지 전제 조건
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
단지 전제 조건
필요한 것
  1. Microsoft Surface Book Keyboard Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the keyboard over so you can see the back panel.
  2. Microsoft Surface Book Keyboard Back Panel Replacement: 2 단계, 이미지 1/2 Microsoft Surface Book Keyboard Back Panel Replacement: 2 단계, 이미지 2/2
    • Insert the plastic opening tool in the crevice between the panel and the keyboard.
    • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
    • The panel is glued down on the inside so this may require some force to lift away the panel.
    • Continue to lift until the panel is completely separated from the keyboard.
    • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
  3. Microsoft Surface Book Keyboard Back Panel Replacement: 3 단계, 이미지 1/1
    • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
결론
Natalie Weisenburger
회원 가입일: 2016년 10월 06일
581 평판
안내서 4개 작성하였습니다
Cal Poly, Team 20-3, Livingston Fall 2016 Cal Poly, Team 20-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G3
4 회원들
안내서 12개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 192
