소개
Use this guide to replace a broken or faulty cooling fan in a Surface Book.
This procedure requires an extensive teardown of the keyboard's internals. You will be removing the motherboard, SD card slot, USB ports, and other internals. Make sure you have a secure place to store the tiny screws you will be removing.
The fan is an essential component of your computer that prevents overheating. It vents the hot air out of your keyboard, keeping it cool. If the fan is damaged and not replaced, you run the risk of permanent damage to your laptop by overheating.
필요한 것
Press and hold the Detach button on the keyboard.
Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
Remove the display.
Flip open the display as far as it will go.
Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
Firmly push the paper clip into the hole.
Pull the base away from the display to detach it.
You should feel slight resistance when pressing against the internal lever arm. If you don’t feel the resistance after about half an inch, back out and try again. Be careful not to push the paper clip too far, as it can scratch the screen bezel from the inside, leaving a visible mark.
With one side detached, pull firmly to pivot the display out to disconnect the second side.
Flip the keyboard over so you can see the back panel.
In this photo, there is a clear crevice around the edge of the panel and the keyboard. On my Surface Book, there is no such crevice. The panel is flush up to the keyboard with a gap that looks to be maybe 0.2mm max. There is no way to fit a tool into the crevice to lift off the panel. Any tips?
Orient your keyboard with the internals facing up and the USB ports on the right.
Remove the larger, black ribbon cable located on the USB card with a plastic opening tool by lifting the tab away from its connector. Again, place the tool underneath the tab and pry it off.
다른 4명이 해당 안내서를 완성하였습니다.
4 Comments
do i need to reapply some sort of glue when putting the cover back on? thnks
What about the thermal heat conducting paste? The connection surface should be cleaned and new paste applied!
Is it possible to equip the lower cover with some small countersunk screws in order to avoid the glueed solution?
Does the surface book 1 1703 tablet work with the model 1704 keyboard?
