주요 콘텐츠로 건너뛰기
Microsoft Surface Book Keyboard USB Port Replacement
필요한 것
  1. Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: 1 단계, 이미지 3개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: 1 단계, 이미지 3개 중 2개 Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: 1 단계, 이미지 3개 중 3개
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
  2. Microsoft Surface Book Keyboard USB Port Replacement, Manually detach the display: 2 단계, 이미지 2개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement, Manually detach the display: 2 단계, 이미지 2개 중 2개
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
  3. Microsoft Surface Book Keyboard USB Port Replacement, Bend a paper clip: 3 단계, 이미지 2개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement, Bend a paper clip: 3 단계, 이미지 2개 중 2개
    • Straighten out one section of a paper clip.
  4. Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: 4 단계, 이미지 3개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: 4 단계, 이미지 3개 중 2개 Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: 4 단계, 이미지 3개 중 3개
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
  5. Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: 5 단계, 이미지 3개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: 5 단계, 이미지 3개 중 2개 Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: 5 단계, 이미지 3개 중 3개
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
  6. Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: 6 단계, 이미지 3개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: 6 단계, 이미지 3개 중 2개 Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: 6 단계, 이미지 3개 중 3개
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
  7. Microsoft Surface Book Keyboard USB Port Replacement, Remove the display: 7 단계, 이미지 1개 중 1개
    • Completely power down your Surface Book before opening it up for any repairs.
  8. Microsoft Surface Book Keyboard USB Port Replacement, Back Panel: 8 단계, 이미지 1개 중 1개
    • Flip the keyboard over so you can see the back panel.
  9. Microsoft Surface Book Keyboard USB Port Replacement: 9 단계, 이미지 2개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement: 9 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool in the crevice between the panel and the keyboard.
    • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
    • The panel is glued down on the inside so this may require some force to lift away the panel.
    • Continue to lift until the panel is completely separated from the keyboard.
    • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
  10. Microsoft Surface Book Keyboard USB Port Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
  11. Microsoft Surface Book Keyboard USB Port Replacement, USB Port: 11 단계, 이미지 1개 중 1개
    • Orient your keyboard with the internals facing up and the USB Port on the right.
  12. Microsoft Surface Book Keyboard USB Port Replacement: 12 단계, 이미지 1개 중 1개
    • Use a plastic opening tool and remove the tab from the USB board
  13. Microsoft Surface Book Keyboard USB Port Replacement: 13 단계, 이미지 2개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement: 13 단계, 이미지 2개 중 2개
    • Lift up the black and gold wires and find the screw hidden there.
    • Use the T3 Torx Screwdriver and remove the four mm screw.
  14. Microsoft Surface Book Keyboard USB Port Replacement: 14 단계, 이미지 1개 중 1개
    • Use the T3 Torx Screwdriver to remove the remaining three 4 mm screws.
  15. Microsoft Surface Book Keyboard USB Port Replacement: 15 단계, 이미지 2개 중 1개 Microsoft Surface Book Keyboard USB Port Replacement: 15 단계, 이미지 2개 중 2개
    • Wiggle the USB Port board away from the keyboard.
    • This may require some force.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Natalie Weisenburger
회원 가입일: 10/06/16
593 평판
안내서 4개를 작성함
Cal Poly, Team 20-3, Livingston Fall 2016 Cal Poly, Team 20-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G3
4 회원들
안내서 12개를 작성함
5가이드 댓글
But how do you remove and re-attach the ribbon cables without damaging them? Seems like an important detail that is left out.
Brandon M - 답글
How do you re-glue the bottom cover back on?
Mike Guarino - 답글
Where do you get the replacement USB board? Is there’s a part number for it that I can look up?
wheetcracker - 답글
Can the same be done for the type c port
Pavan Kumar - 답글
There are quite a few questions raised Tunnel Rush. Maybe I missed a few details in the manual.
stevens gomez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 66
전체 시간: 6,473
