소개
The Microsoft Surface Headphones headband cushion allows for a comfortable listening experience. If you've noticed that the cushioning doesn't seem so comfortable anymore, it might be time to replace it. This guide will show you how to do just that!
필요한 것
Starting at the peak of the headband, push inward below the seam, between the plastic headband and cushion, to create a gap.
Work your way down the headband until the cushion is exposed.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
How do you put back the the cushion cover?
