주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Keyboard (WS2-00025) Teardown
필요한 것
  1. Microsoft Surface Keyboard (WS2-00025) Teardown, Microsoft Surface Keyboard Teardown: 1 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown, Microsoft Surface Keyboard Teardown: 1 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown, Microsoft Surface Keyboard Teardown: 1 단계, 이미지 3개 중 3개
    • The box is a scaled representation of the product. It's pretty much spot on.
    • It's a box - no It's a keyboard - no it's a box...
  2. Microsoft Surface Keyboard (WS2-00025) Teardown: 2 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 2 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 2 단계, 이미지 3개 중 3개
    • Why the teardown? I received this keyboard from a "used" ebay listing, and it turned out to have a broken key.
    • The key tabs that hold the key to the base of the keyboard were sheared off, making repair of that beloved windows key pretty much impossible.
  3. Microsoft Surface Keyboard (WS2-00025) Teardown: 3 단계, 이미지 1개 중 1개
    • Hidden under the left-hand side of the keyboard is the Bluetooth sync button.
  4. Microsoft Surface Keyboard (WS2-00025) Teardown: 4 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 4 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 4 단계, 이미지 3개 중 3개
    • The back of the keyboard features a screwless battery compartment and not much else.
    • The battery cover is held in place by neodymium magnets and the metalized plastic coating on the cover.
    • The solid click of the battery compartment.
  5. Microsoft Surface Keyboard (WS2-00025) Teardown: 6 단계, 이미지 1개 중 1개
    • Before I tear apart a product, I like to take the time to analyze the exterior construction and overall build of the item. This gives me a better idea of how the product was assembled and mass produced.
    • The best way to do this is by looking for seams or imperfections in the build construction.
    • Does the part bow or flex when a small stress is applied? Are there any large gaps in the build? Are there any obvious stickers covering fasteners?
    • This is how I pictured the keyboard to be constructed in my head. I had a feeling that it was one gigantic glued and snapped together assembly, but I needed to verify that first.
  6. Microsoft Surface Keyboard (WS2-00025) Teardown: 7 단계, 이미지 2개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 7 단계, 이미지 2개 중 2개
    • After inspecting the seams, I check under the stickers and glued-on rubber feet. Still no signs of screws.
  7. Microsoft Surface Keyboard (WS2-00025) Teardown: 8 단계, 이미지 1개 중 1개
    • It would be quite underhanded to put screws under the keys. Luckily that is not the case here.
    • To remove a key, wedge a plastic spudger under the key from the top most edge. Apply a bit of downward pressure on the spudger to lift the key. The key should make popping sounds and unlatch from the metal clips underneath the key that hold it to the keyboard frame.
  8. Microsoft Surface Keyboard (WS2-00025) Teardown: 9 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 9 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 9 단계, 이미지 3개 중 3개
    • Fearing the worst, I cut off a strip of wax paper and fully removed the bottom most rubber foot of the keyboard.
    • Still no screws in sight.
  9. Microsoft Surface Keyboard (WS2-00025) Teardown: 10 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 10 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 10 단계, 이미지 3개 중 3개
    • The fit and finish on this keyboard is quite good - too good in fact. There is practically no room to fit a prying tool in any seam of the keyboard.
  10. Microsoft Surface Keyboard (WS2-00025) Teardown: 11 단계, 이미지 2개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iOpener
    $24.99
    • With the amount of double sided tape and glue inside this keyboard, it would be wise to use an iOpener tool or heatgun before beginning to pry open the keyboard.
    • I used a heatgun a bit later into the prying process because I was fearful of melting and deforming the back plastic of the keyboard. Luckily, adjusting the heatgun to its lowest setting activated the glue enough to become pliable.
  11. Microsoft Surface Keyboard (WS2-00025) Teardown: 12 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 12 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Now for the prying bit. Ready your barrage of prying tools! I used plastic spudgers, metal spudgers, plastic cards, and X-ACTO knifes to get this open.
    • The gap between the aluminum shell and plastic rear plate was so tight I had to use an X-ACTO knife with square-headed No. 18 Blade to widen the gap enough to slide in my metal spudger.
    • Important note: Don't ever pry with an X-ACTO knife, the blades are not meant for prying. If you pry with them, they will crack and can potentially cut into your hand.
  12. Microsoft Surface Keyboard (WS2-00025) Teardown: 13 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 13 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 13 단계, 이미지 3개 중 3개
    • Only after applying heat was I able to get anywhere with prying.
    • I'll put it this way: two metal prying tools is simply not enough! Thankfully I had some spare giftcards lying around :D
  13. Microsoft Surface Keyboard (WS2-00025) Teardown: 14 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 14 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 14 단계, 이미지 3개 중 3개
    • With a few more rounds of heat and prying I was finally getting somewhere.
  14. Microsoft Surface Keyboard (WS2-00025) Teardown: 15 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 15 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 15 단계, 이미지 3개 중 3개
    • The two main halves started to separate with some persuasion.
    • Giftcards really come in handy. They allow for some prying action without damaging sandwiched parts. If I used a metal spudger for this step, I could have risked tearing the one ribbon cable inside this keyboard. Save your giftcards!
  15. Microsoft Surface Keyboard (WS2-00025) Teardown: 16 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 16 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 16 단계, 이미지 3개 중 3개
    • Finally apart!
    • With the keyboard apart, it is evident that Microsoft used double sided tape around each key and glue on the exterior keyboard edge.
  16. Microsoft Surface Keyboard (WS2-00025) Teardown: 17 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 17 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 17 단계, 이미지 3개 중 3개
    • Close-up on the Battery compartment.
    • Neodymium magnets on both terminals and the top of the compartment!
    • The top magnets actually hold the AAA batteries to the top part of the plastic battery section. The only way to easily remove the batteries from the housing is to forcefully tap the top of the keyboard.
  17. Microsoft Surface Keyboard (WS2-00025) Teardown: 18 단계, 이미지 2개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 18 단계, 이미지 2개 중 2개
    • The main PCB is rather small measuring 12mm x 170mm.
    • The back side of the PCB is sparse with just a ribbon cable connector and some solder joints.
    • The flex circuit board for the rubber dome keys terminates into a multi-wire ribbon cable which connects to the main PCB.
  18. Microsoft Surface Keyboard (WS2-00025) Teardown: 19 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 19 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 19 단계, 이미지 3개 중 3개
    • The top side of the PCB is more densely packed than the back side. There is one main chip, some passive components, a battery connector, the Bluetooth switch and Bluetooth antenna.
    • Nordic Semiconductor nRF51822
    • 2 Pin JST battery connector
    • Button for Bluetooth pairing.
  19. Microsoft Surface Keyboard (WS2-00025) Teardown: 20 단계, 이미지 2개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 20 단계, 이미지 2개 중 2개
    • A closer look at the Bluetooth antenna. Even though this looks more like a bracket than an antenna, it has been sized appropriately for the 2.4ghz bandwidth.
    • Real-time clock
    • Microchip Microchip VUA Power IC / Voltage regulator
  20. Microsoft Surface Keyboard (WS2-00025) Teardown: 21 단계, 이미지 3개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 21 단계, 이미지 3개 중 2개 Microsoft Surface Keyboard (WS2-00025) Teardown: 21 단계, 이미지 3개 중 3개
    • It is rather interesting that Microsoft intentionally left an empty ribbed space in the bottom compartment of the keyboard.
    • The Microsoft Modern Keyboard anyone?
  21. Microsoft Surface Keyboard (WS2-00025) Teardown: 22 단계, 이미지 2개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 22 단계, 이미지 2개 중 2개
    • Continuing on the analysis of the surface keyboard, there is something special that Microsoft has hidden from its customers - right in plain sight.
    • *Incoming lyrical adaptations*
    • Why was typing meant to be hard?
    • Why ain't you a force of choice?
    • Why the whole world love my voice?
    • Why I try to tell em its my keyboard stroke, son
    • And you know why they made the new surface?
    • 'cause there's no backlight in the old ones - that's why!
  22. Microsoft Surface Keyboard (WS2-00025) Teardown: 24 단계, 이미지 2개 중 1개 Microsoft Surface Keyboard (WS2-00025) Teardown: 24 단계, 이미지 2개 중 2개
    • One of the biggest complaints of the surface keyboard is that it doesn't feature a backlight.
    • It is rather sad that Microsoft chose to design a keyboard with several intentional iterations in mind, instead of just producing the best slim keyboard they could.
    • A quick design change such as adding a hole under each key, an optical diffusing layer and a few LEDs would have added a simple and functional backlight.
    • For further investigation into this keyboard, check out my Surface Keyboard Hacking Project
결승점
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Anthony Kouttron
회원 가입일: 02/24/17
5,730 평판
안내서 5개를 작성함
17가이드 댓글
Man, how rude to use glue for a keyboard! I wanted to open my Surface Ergonomic keyboard in hopes it had JTAG or other diagnostic port that would enable me to twiddle with its brain, since macOS does not believe it is a keyboard but rather just a generic bluetooth HID :(
Thank you for sacrificing your keyboard to spare me the pain of discovering the hard way that my keyboard is glued together
Matthew L Daniel - 답글
No problem! I’m glad you enjoyed the teardown. I sure wish they used screws instead of adhesive. It would make retrofitting a backlight far easier.
Anthony Kouttron -
If I discover anything interesting from probing that 10 pin unpopulated header I’ll be sure to provide an update.
Anthony Kouttron -
hey Anthony, i have the same problem with one of the keys (the big “0” on the numerical part). Did you find a solution for fixing the “key tabs that hold the key” that sheared of of mine as well?
Bas Flipsen - 답글
Hi Bas! Unfortunately, I did not attempt to repair the broken aluminum key tabs that hold the key in place. However, I can point you in the right direction if you want to get creative and try a DIY fix. Carefully pop another key off your keyboard with something wood or plastic (like a plastic spudger) and analyze the metal locking tab design Microsoft implemented. Find another piece of aluminum of the same thickness and carefully cut out that tab shape. Try adhering your designed tab to the location where the broken aluminum key tab is situated. Epoxy or titanium putty should bond aluminum to aluminum. I would use a toothpick or sewing pin as an adhesive applicator. I think you will have success if you take your time and be patient. Good luck!
Anthony Kouttron -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 83
지난 30일: 410
전체 시간: 34,173
