주요 콘텐츠로 건너뛰기
Microsoft Surface RT Kick-stand Replacement
필요한 것
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: 1 단계, 이미지 1/2 Microsoft Surface RT Kick-stand Replacement, Kick-stand: 1 단계, 이미지 2/2
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Kevin Hua
회원 가입일: 01/11/13
1,615 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-23, Forte Winter 2013 Cal Poly, Team 17-23, Forte Winter 2013 회원
CPSU-FORTE-W13S17G23
5 회원들
안내서 17개 작성하였습니다
댓글 12개
Where do you get the replacement kickstand from?
Ray - 답글
is this compatible with surface pro 1 ?
arqueiro - 답글
Do you offer a replacement kickstand for the surface rt 2?
allie - 답글
Does this replacement kickstand come with the screws also?
Andrea Thompson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 30
전체 시간: 40,584
