주요 콘텐츠로 건너뛰기
Microsoft Surface Laptop 3 13.5" Feet Replacement
필요한 것
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: 1 단계, 이미지 1/2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: 1 단계, 이미지 2/2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: 2 단계, 이미지 1/2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: 2 단계, 이미지 2/2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: 3 단계, 이미지 1/3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: 3 단계, 이미지 2/3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: 3 단계, 이미지 3/3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: 4 단계, 이미지 1/3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: 4 단계, 이미지 2/3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: 4 단계, 이미지 3/3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 5 단계, 이미지 1/2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 5 단계, 이미지 2/2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 6 단계, 이미지 1/3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 6 단계, 이미지 2/3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: 6 단계, 이미지 3/3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
결론
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
114,422 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,275개 작성하였습니다
댓글 한 개
Nice, that good for me, first time :D
TrungLun0112 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 41
30일 전: 174
전체 시간: 5,761
