주요 콘텐츠로 건너뛰기
Microsoft Surface Pen Tip Replacement
필요한 것
  1. Microsoft Surface Pen Tip Replacement, Tip: 1 단계, 이미지 1/3 Microsoft Surface Pen Tip Replacement, Tip: 1 단계, 이미지 2/3 Microsoft Surface Pen Tip Replacement, Tip: 1 단계, 이미지 3/3
    • Order the Microsoft Surface Pen tip replacement kit.
    • Hold your pen at an angle and unscrew the top part of the pen.
  2. Microsoft Surface Pen Tip Replacement: 2 단계, 이미지 1/3 Microsoft Surface Pen Tip Replacement: 2 단계, 이미지 2/3 Microsoft Surface Pen Tip Replacement: 2 단계, 이미지 3/3
    • Extract the tip now that it is fully exposed.
    • When you extract the tip, make sure don't do it too hard. The inside of the pen can be broken.
  3. Microsoft Surface Pen Tip Replacement: 3 단계, 이미지 1/3 Microsoft Surface Pen Tip Replacement: 3 단계, 이미지 2/3 Microsoft Surface Pen Tip Replacement: 3 단계, 이미지 3/3
    • After you extract the tip, roll the tissue on toothpick.
    • I recommend cutting the tissue in half.
  4. Microsoft Surface Pen Tip Replacement: 4 단계, 이미지 1/3 Microsoft Surface Pen Tip Replacement: 4 단계, 이미지 2/3 Microsoft Surface Pen Tip Replacement: 4 단계, 이미지 3/3
    • Clean the inside of the top detachable part of the pen with a toothpick covered with tissue.
    • Make sure there is no residue on the edge.
  5. Microsoft Surface Pen Tip Replacement: 5 단계, 이미지 1/3 Microsoft Surface Pen Tip Replacement: 5 단계, 이미지 2/3 Microsoft Surface Pen Tip Replacement: 5 단계, 이미지 3/3
    • Choose the tip that you would like to use and insert in a hole.
  6. Microsoft Surface Pen Tip Replacement: 6 단계, 이미지 1/3 Microsoft Surface Pen Tip Replacement: 6 단계, 이미지 2/3 Microsoft Surface Pen Tip Replacement: 6 단계, 이미지 3/3
    • Screw the detachable part of the pen back on.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Junseok Baek
회원 가입일: 05/19/20
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 76
전체 시간: 5,787
