주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 2 LCD Display Replacement
필요한 것
  1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: 1 단계, 이미지 2개 중 1개 Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: 1 단계, 이미지 2개 중 2개
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 LCD Display Replacement: 2 단계, 이미지 1개 중 1개
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 LCD Display Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 LCD Display Replacement: 4 단계, 이미지 3개 중 1개 Microsoft Surface Pro 2 LCD Display Replacement: 4 단계, 이미지 3개 중 2개 Microsoft Surface Pro 2 LCD Display Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Mathew B
회원 가입일: 09/19/16
323 평판
안내서 2개를 작성함
USF Tampa, Team 6-2, Remmell Fall 2016 USF Tampa, Team 6-2, Remmell Fall 2016 회원
USFT-REMMELL-F16S6G2
4 회원들
안내서 11개를 작성함
5가이드 댓글
After replacing the screen my surface will turn on but the screen is just black.... in device manager its showing up as a 'Digital Flat Panel'
yet the screen is still black.. faulty replacement panel???
austin jones - 답글
Same thing happening to me… :(
Marco - 답글
I did this procedure but i dont know why the display is not working it blink and then turnoff can somebody help me how to fix this problem
Smart Instruments - 답글
I purchased a screen replacement (LCD and Digitizer), but apparently, the flex from the motherboard to the screen (the small connector in red as well as the one on the lcd) are missing. Is there a way or place I can purchase just those flex? Or do I need to get a whole new motherboard?
Roselite - 답글
Myne doesn't boot. The display is dack nothing happens. It's like it's not charging. What do I do. Thanks
ARCHER TABULEY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 58
전체 시간: 15,494
