주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 3 Kickstand Replacement
필요한 것
  1. Microsoft Surface Pro 3 Kickstand Replacement, Kickstand: 1 단계, 이미지 1/1
    • Lift the kickstand to a 90º angle to expose the hinge screws.
  2. Microsoft Surface Pro 3 Kickstand Replacement: 2 단계, 이미지 1/2 Microsoft Surface Pro 3 Kickstand Replacement: 2 단계, 이미지 2/2
    • Remove the four 3.5 mm T5 screws—two on each side.
  3. Microsoft Surface Pro 3 Kickstand Replacement: 3 단계, 이미지 1/2 Microsoft Surface Pro 3 Kickstand Replacement: 3 단계, 이미지 2/2
    • Wiggle the kickstand gently back and forth to disengage the two lightly-adhered tabs connecting the center of the kickstand to the main body.
    • Remove the kickstand from the back cover of the Surface Pro 3.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,125 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
The title for this repair guide is incorrect. This is for the kickstand, not the battery.
Michael Kavanaugh - 답글
Hi Michael, thanks for catching this! It looks like someone changed it and it was ok’d on accident. We’ve changed it back.
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 40
전체 시간: 4,156
