소개
The Surface Pro 4's heat sink cooling system consists of copper tubing and a connected copper plate. Here is how to remove it for replacement or to access the components below.
필요한 것
Both sections of the heat sink are connected to the motherboard via a panel which is covered by a metal casing.
Remove the casing by prying around the edges and then lifting the entire piece once it is loose.
다른 10명이 해당 안내서를 완성하였습니다.
