주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Pro 4 Screen Adhesive Replacement
필요한 것
  1. Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3개 중 1개 Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3개 중 2개 Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3개 중 3개
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 4 Screen Adhesive Replacement, Apply the new adhesive: 2 단계, 이미지 2개 중 1개 Microsoft Surface Pro 4 Screen Adhesive Replacement, Apply the new adhesive: 2 단계, 이미지 2개 중 2개
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 4 Screen Adhesive Replacement, Install the display: 3 단계, 이미지 1개 중 1개
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
98,250 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 43
지난 30일: 147
전체 시간: 11,764
