주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 5 Screen Adhesive Replacement
필요한 것
  1. Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3개 중 1개 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3개 중 2개 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3개 중 3개
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: 2 단계, 이미지 2개 중 1개 Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: 2 단계, 이미지 2개 중 2개
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 5 Screen Adhesive Replacement, Install the display: 3 단계, 이미지 1개 중 1개
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro 6 answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
92,441 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 47
전체 시간: 3,911
