주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 6 Kickstand Replacement
필요한 것
  1. Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 1/3 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 2/3 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 3/3
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: 2 단계, 이미지 1/2 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: 2 단계, 이미지 2/2
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 1/3 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 2/3 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 3/3
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 1/3 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 2/3 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 3/3
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,125 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 7개
Any way to replace the hinges themself?
Only-Wonder - 답글
Also trying to find this out.
Bobby Stephenson -
Thank you so much. I use the Surface 6 in portrait mode to read and use the kickstand as a grip/hand rest to prevent wrist strain. This meant the screws came loose constantly and I had to try and tighten them using my fingertip; not ideal. With the newly purchased Manta kit, and this guide, they are properly tightened again for the first time in over a year.
Chris Goodluck - 답글
If you find that that the kickstand screws are still coming loose, I suggest applying a dab of blue Loctite (or nail polish if in a pinch) to the screws to help them hold in place.
Arthur Shi -
The hinge mechanism has come completely loose so that the stand will not glide back into position. I thought it was the adhesive pads keeping it in place. Reading the instructions above, I now see that these pads can be put back into position. There is a whole Youtube showing the headaches of this kickstand hinge situation. The best bet is to buy a cover with a kickstand attached.
zsugahill - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 48
30일 전: 192
전체 시간: 21,063
