주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Pro 7+ Kickstand Replacement
필요한 것
  1. Microsoft Surface Pro 7+ Kickstand Replacement, Before you begin: 1 단계, 이미지 1개 중 1개
    • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
  2. Microsoft Surface Pro 7+ Kickstand Replacement, Open the kickstand: 2 단계, 이미지 2개 중 1개 Microsoft Surface Pro 7+ Kickstand Replacement, Open the kickstand: 2 단계, 이미지 2개 중 2개
    • Open the kickstand to about 90 degrees.
  3. Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand screws: 3 단계, 이미지 3개 중 1개 Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand screws: 3 단계, 이미지 3개 중 2개 Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand screws: 3 단계, 이미지 3개 중 3개
    • While holding the kickstand behind the hinge with your finger, use a Torx Plus 3IP screwdriver to remove the two 2.7 mm‑long screws from each hinge (four total).
    • Make sure the screws don't fall into the hinge cutouts.
  4. Microsoft Surface Pro 7+ Kickstand Replacement, Lay the kickstand down: 4 단계, 이미지 2개 중 1개 Microsoft Surface Pro 7+ Kickstand Replacement, Lay the kickstand down: 4 단계, 이미지 2개 중 2개
    • Lay the kickstand down towards the top of the device so it's lying flat.
  5. Microsoft Surface Pro 7+ Kickstand Replacement, Reposition the hinges: 5 단계, 이미지 3개 중 1개 Microsoft Surface Pro 7+ Kickstand Replacement, Reposition the hinges: 5 단계, 이미지 3개 중 2개 Microsoft Surface Pro 7+ Kickstand Replacement, Reposition the hinges: 5 단계, 이미지 3개 중 3개
    • Wrap your finger in a clean cloth and push both hinges down to about 30 degrees.
  6. Microsoft Surface Pro 7+ Kickstand Replacement, Flip the kickstand over: 6 단계, 이미지 2개 중 1개 Microsoft Surface Pro 7+ Kickstand Replacement, Flip the kickstand over: 6 단계, 이미지 2개 중 2개
    • Flip the kickstand towards the bottom of the device so it's resting on the hinges.
  7. Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand: 7 단계, 이미지 2개 중 1개 Microsoft Surface Pro 7+ Kickstand Replacement, Remove the kickstand: 7 단계, 이미지 2개 중 2개
    • Firmly secure the device to your work surface with one hand, and use your free hand to pull the kickstand out until both foam tabs slide out.
    • If you're having trouble, make sure the kickstand isn't getting stuck on the hinges—it should slide out fairly easily.
결론
Spencer Day
회원 가입일: 09/14/22
188,078 평판
안내서 1,187개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 27
