주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 7 Kickstand Replacement
필요한 것
  1. Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 1/3 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 2/3 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 3/3
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: 2 단계, 이미지 1/2 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: 2 단계, 이미지 2/2
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 1/3 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 2/3 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 3/3
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 1/3 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 2/3 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 3/3
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
73,429 평판
안내서 288개 작성하였습니다
댓글 2개
One of the hinges broke on my Surface Pro 6.
1. I removed the broken hinge, closed the kickstand and duct taped the seam.
2. I opened the kickstand wide and duct taped the seam.
The single hinge and duct tape seem to be working!
"Spare the duct tape, spoil the job." - Red Green
P Best - 답글
What are the parts used for this fix?
Andrea Shaw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 52
30일 전: 212
전체 시간: 6,575
