주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 7 Kickstand Replacement
필요한 것
  1. Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 3개 중 1개 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 3개 중 2개 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: 1 단계, 이미지 3개 중 3개
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: 2 단계, 이미지 2개 중 1개 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: 2 단계, 이미지 2개 중 2개
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 3개 중 1개 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 3개 중 2개 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: 3 단계, 이미지 3개 중 3개
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 3개 중 1개 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 3개 중 2개 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: 4 단계, 이미지 3개 중 3개
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,281 평판
안내서 290개를 작성함
2가이드 댓글
One of the hinges broke on my Surface Pro 6.
1. I removed the broken hinge, closed the kickstand and duct taped the seam.
2. I opened the kickstand wide and duct taped the seam.
The single hinge and duct tape seem to be working!
"Spare the duct tape, spoil the job." - Red Green
P Best - 답글
What are the parts used for this fix?
Andrea Shaw - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 85
전체 시간: 9,403
