주요 콘텐츠로 건너뛰기
Microsoft Surface Pro 7 Screen Adhesive Replacement
필요한 것
  1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 1/3 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 2/3 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 1 단계, 이미지 3/3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: 2 단계, 이미지 1/2 Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: 2 단계, 이미지 2/2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: 3 단계, 이미지 1/1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
75,409 평판
안내서 288개 작성하였습니다
댓글 2개
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - 답글
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 35
30일 전: 153
전체 시간: 4,595
