주요 콘텐츠로 건너뛰기
Microsoft Surface Pro Kickstand Replacement
필요한 것
  1. Microsoft Surface Pro Kickstand Replacement, Kickstand: 1 단계, 이미지 1개 중 1개
    • Turn the tablet so the back is facing up.
    • Lift the kickstand to access the screws.
    • Remove the two T5 Torx screws:
    • One from the left hinge
    • One from the right hinge
  2. Microsoft Surface Pro Kickstand Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Mark
회원 가입일: 10/09/13
756 평판
안내서 1개를 작성함
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013 회원
CPSU-REGAN-F13S8G20
4 회원들
안내서 16개를 작성함
1가이드 댓글
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 90
전체 시간: 40,283
