이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This replacement guide will help you with the following:
Completely remove the old kick-stand and install a new one.
필요한 것
Turn the tablet so the back is facing you
Pull up on the kick-stand to open up the stand
Remove the kick-stand by unscrewing the two T5 Torx screws located on the left and right sides.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - 답글
