필요한 것
동영상 개요
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Apart from that sweet kickstand, we're not sure what to expect here—and that's a good thing. Our teardown unit boasts the following specs:
13" PixelSense display with 2880 × 1920 resolution (267 ppi)
Microsoft SQ1 3.0 GHz ARM processor (based on Qualcomm's Snapdragon 8cx) with a Microsoft SQ1 Adreno 685 GPU
8 GB of LPDDR4X RAM (16 GB optional)
Removable 128 GB solid state drive (256 GB or 512 GB optional)
5 MP and Windows Hello front-facing cameras, and one 10 MP rear-facing camera
Two USB-C ports and one Surface Connect port (headphone jacks are apparently not professional)
Wi-Fi 5 802.11ac, Bluetooth 5.0, Gigabit LTE
Unlike the fairly-iterative Surface Pro 7 released last month, the Pro X is a complete redesign—the first in many years. And it comes with a new model number: 1876.
If you need a teardown TL;DR, here's an X-ray overview from Creative Electron showing everything on our agenda.
Compared to the Pro 7, we note the Pro X's rounded corners, narrower profile, and reductified port selection.
If you're in the market for a thin professional Windows tablet, wave goodbye to the USB-A port, MicroSD card slot, and headphone jack. USB-C is the future, it seems.
With the kickstands raised, we can see that the Pro X gets a sleeker hinge—likely shaving off precious thickness.
We poke the (magnetically secured!) trap door with our SIM eject bit, and...
Voilà! Underneath, an SSD (held down by a T3 screw) and a SIM slot!
And hey, this SSD looks super familiar. A quick comparison with the 256 GB drive we pulled from the Surface Laptop 3 confirms both devices are using the same drive. Standardization is great for repairs!
As an experiment, we try powering on the Pro X sans-SSD, and... no sign of life. We wouldn't expect it to boot up—but it's so dead, we sort of suspect the SSD acts as a battery kill switch like we found in the Laptop 3.
Unlike the Laptop 3 with its hidden screws, we don't find any fasteners lurking under this kickstand. Alas, this probably won't be a magical opening experience. We arm our iOpeners and brace ourselves for heavy adhesives...
이 단계에 사용된 도구:iMac Opening Wheel$7.99-
But first—a little suction (maybe more than a little) to try and lift the display near the speaker grille.
Look ma, no heat! Perhaps our iOpeners can take the day off—we're able to cut right in, iMac-style.
No goopy tendrils hold this display down—it comes off clean!
This friendly, cuttable foam adhesive is truly an improvement over previous Surface Pro devices—and pretty much all other tablets with glued-down screens. High heat, furious cutting and prying, glue-covered tools, and (frequently) accidentally cracked screens are "features" we will happily kiss goodbye.
Not pictured: the teardown team performing a celebratory dance around the photo table. We never thought we'd get into a Surface Pro this easily.
While relatively painless, this opening procedure is not without hurdles—we see a few flex cables along the bottom of the display, dangerously close to the path of our cutting tools.
That said, it gets even painless-er when we start removing the adhesive. It peels off like magic—no mess! This is the kind of change we've been pleading for. If you must glue together a super thin, space-constrained device, this is how you should do it. (But don't do it on a desktop, okay? Because that's just lame.)
Our excitement is real, but let's pause to peruse these display chips. We've got:
Microsoft X904163 and X904169 display drivers
Winbond Q16FWUXB2 1921-681C DR80006
Analogix ANX2684 1920 C975AA
SiW SW50014A 8266631T 1844
SiW SW5077 J004370V 1920
이 단계에 사용된 도구:Pro Tech Toolkit$74.95-
We came armed with our entire Pro Tech Toolkit, but only need a single Torx bit to twirl away the heat sink screws.
Here's one thing we're glad Microsoft didn't change: All the screws so far are just Torx. That was the previous Surface Pro's sole positive repairability point, and it's good to see it return.
Supporting the heat sink is an interesting bit of
abstract artintermediate frame-age. We briefly pause to contemplate its meaning before pulling it away from the board. -
With the heat sink and quite a few shields and screws out of the way, the motherboard slides out. Time for some silicon sleuthing!
Here's what we dug up:
Samsung K3UH5H50AMJGCL 4 GB LPDDR4X RAM x2, for 8 GB total
NXP LPC54S00TJ EV180 microcontroller
Macronix MX25U1635E serial NOR flash memory
Winbond 26Q256JW 256 Mb serial flash memory
Qualcomm SDR8150 RF transceiver and modem
Qorvo 78052 14CEM RF Fusion MHB
The back side of board is devoid of interesting silicon, but we can't help but notice the strange silver jumper wire clinging to it. Hey wait a minute, this thing actually looks kinda familiar.
What's it for? You're welcome to inspect where it's routed and try to guess!
We think it may be a shielded diversity antenna of some kind, with a grounded exterior to insulate RF to and from the interior signal lead. The accompanying sticker NEW SAM could be labelling the wire as a Surface Antenna Mount.
That said, NEW SAM could be anything: Super Activity Monitor; Silver Aerobic Master; Slippery Agile Meerkat; Solidified Aerodynamic Meter ... The possibilities are endless. Leave your NEW SAM guesses in the comments below.
We're used to seeing some fancy mechanics driving the kickstand hinge in these Surface Pros, but this time we're treated to even more fancy mechanics.
The SSD cover sits on one side of a tiny see-saw, waiting for a friendly SIM eject tool or paperclip to come along and sit on the other side. When that happens, the see-saw pushes the SSD cover away from the case, and bam! Just like that you can upgrade your storage.
When we're done at the world's smallest playground, we move over to the SSD interface and SIM reader, which come out as one module.
Step right up and get yer battery specs! We spent long enough wrestling with the last uberglued Microsoft battery to know better than to mess with this one. We opt to leave it be.
What's left? Modular USB ports, flanked by the kickstand hinge mechanism and the case buttons. And at the far end lies the Surface Connect port—also modular.
You may be surprised to read the word modular so much in a Surface Pro teardown. So are we! We've done some deep breathing and pinched ourselves multiple times, but this does appear to be reality.
If only they could inno-vent some way to secure that battery in a more repair-friendly way. Maybe next time?
Ta-da! That's all for now, folks. Here are all the little bits of this Surface.
It would seem that Microsoft has placed at least one foot on the repairability train—between this Pro X and the Laptop 3, we can hardly believe all the repair-focused changes they've made!
The SSD is truly user-replaceable, requiring only a SIM eject pin and a T3 driver—no need to remove the screen. That’s awesome to see in such a slim form factor. As a bonus, it’s the same SSD as in the Laptop 3, meaning more standardization and better support from third parties.
In a first for tablets, the display is held down with friendly foam adhesive that doesn’t require heat or solvents to remove. We still don’t like adhesive, but this is a fair compromise on a tablet.
What does all that mean? Time to give this thing a score.
- The user-removable SSD makes for easy upgrades and data security that doesn't require device destruction.
- To the extent that screws are used, they are all standard Torx fasteners.
- Many components are modular and can be replaced independently.
- (Almost) all repairs require display removal, with an improved procedure that needs no heat, but necessitates careful prying.
- The battery is firmly glued in place, with its connector pinned under the motherboard—requiring near-total disassembly for service.
최종 결론
수리 용이성 점수
(10은 가장 쉬운 수리를 뜻합니다)
댓글 26개
You guys sound truly excited… So am I while reading this. A big win for the repair community and consumers as a whole!
Hey Andru! Sorry, the details may be a little murky amidst our excitement! Adhesive holds the display in place, but it’s a very nice foam adhesive that doesn’t require heat or excessive prying to separate. All the previous Surface Pro devices use a tacky adhesive that is very difficult to separate without damaging the display.
