주요 콘텐츠로 건너뛰기
Microtek ScanMaker 5900 Motor Tread Replacement
필요한 것
  1. Microtek ScanMaker 5900 Motor Tread Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement, Remove serial port connection: 1 단계, 이미지 3개 중 3개
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 Motor Tread Replacement, Remove Lid: 2 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Remove Lid: 2 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement, Remove Lid: 2 단계, 이미지 3개 중 3개
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 Motor Tread Replacement, Detach plastic latches: 3 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Detach plastic latches: 3 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement, Detach plastic latches: 3 단계, 이미지 3개 중 3개
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 Motor Tread Replacement, Continue latch detachment: 4 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Continue latch detachment: 4 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement, Continue latch detachment: 4 단계, 이미지 3개 중 3개
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 Motor Tread Replacement, Fully remove the upper lid: 5 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Fully remove the upper lid: 5 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement, Fully remove the upper lid: 5 단계, 이미지 3개 중 3개
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 Motor Tread Replacement, Stepper Motor: 6 단계, 이미지 2개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Stepper Motor: 6 단계, 이미지 2개 중 2개
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  7. Microtek ScanMaker 5900 Motor Tread Replacement: 7 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement: 7 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement: 7 단계, 이미지 3개 중 3개
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  8. Microtek ScanMaker 5900 Motor Tread Replacement: 8 단계, 이미지 3개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement: 8 단계, 이미지 3개 중 2개 Microtek ScanMaker 5900 Motor Tread Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
  9. Microtek ScanMaker 5900 Motor Tread Replacement, Motor Tread: 9 단계, 이미지 2개 중 1개 Microtek ScanMaker 5900 Motor Tread Replacement, Motor Tread: 9 단계, 이미지 2개 중 2개
    • Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread.
    • Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
    • Using a #2 Philips Screwdriver, unscrew the single 5.88mm screw holding the mount of the plastic wheel in place.
  10. Microtek ScanMaker 5900 Motor Tread Replacement: 10 단계, 이미지 1개 중 1개
    • The plastic wheel and it's mount will be loose.
    • Remove the shaft holding the plastic wheel and the mount together
    • The tread will be completely loose.
결론
작성자
4다른 기여자 명과 함께
Steven Shaginyan
회원 가입일: 10/12/11
39 평판
안내서 4개를 작성함
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 회원
CPSU-REGAN-F11S6G9
2 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 1,455
