주요 콘텐츠로 건너뛰기
Microtek ScanMaker 5900 New Ribbon Cable Replacement
필요한 것
  1. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove serial port connection: 1 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove serial port connection: 1 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove serial port connection: 1 단계, 이미지 3/3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove Lid: 2 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove Lid: 2 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove Lid: 2 단계, 이미지 3/3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Detach plastic latches: 3 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Detach plastic latches: 3 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Detach plastic latches: 3 단계, 이미지 3/3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Continue latch detachment: 4 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Continue latch detachment: 4 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Continue latch detachment: 4 단계, 이미지 3/3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Fully remove the upper lid: 5 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Fully remove the upper lid: 5 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Fully remove the upper lid: 5 단계, 이미지 3/3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove outer plastic housing: 6 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove outer plastic housing: 6 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove outer plastic housing: 6 단계, 이미지 3/3
    • Lift up the central plastic housing inside the scanner.
    • There are four plastic tabs located on the outer plastic housing. Push on each of these and pull to remove it.
    • Underneath you will see that the ribbon cable is attached to the circuit board.
  7. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 7 단계, 이미지 1/2 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Grab onto ribbon cable with tweezers and gently pull until it come outs.
  8. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from central plastic housing: 8 단계, 이미지 1/2 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from central plastic housing: 8 단계, 이미지 2/2
    • Simply remove the ribbon cable from within the holes it is wrapped through.
  9. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove the ribbon cable from between the plastic prongs on the bottom of the scanner.: 9 단계, 이미지 1/1
    • Grab the ribbon cable, and gently pull it off of the bottom of the scanner.
  10. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 10 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 10 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable from circuit board: 10 단계, 이미지 3/3
    • Peel back the sticky metal from the other side of the ribbon cable.
    • Use tweezers to gently remove the ribbon cable from the circuit board.
  11. Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable: 11 단계, 이미지 1/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable: 11 단계, 이미지 2/3 Microtek ScanMaker 5900 New Ribbon Cable Replacement, Remove ribbon cable: 11 단계, 이미지 3/3
    • Remove the metal housing for the ribbon cable at the base of the scanner.
    • Use the tweezers to slide off the metal housing.
    • The ribbon cable is now completely free to be replaced.
결론
Taylor Nesheim
회원 가입일: 10/11/11
59 평판
안내서 7개 작성하였습니다
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 회원
CPSU-REGAN-F11S6G9
2 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 1,678
