주요 콘텐츠로 건너뛰기
Midea MRU03M2ABB Upright Freezer Door Replacement
필요한 것
  1. Midea MRU03M2ABB Upright Freezer Door Replacement, Door: 1 단계, 이미지 2개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement, Door: 1 단계, 이미지 2개 중 2개
    • Unplug the device.
    • Only unplug when your hand is dry.
  2. Midea MRU03M2ABB Upright Freezer Door Replacement: 2 단계, 이미지 1개 중 1개
    • Empty the shelves.
  3. Midea MRU03M2ABB Upright Freezer Door Replacement: 3 단계, 이미지 3개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 3 단계, 이미지 3개 중 2개 Midea MRU03M2ABB Upright Freezer Door Replacement: 3 단계, 이미지 3개 중 3개
    • Use a plastic spatula to remove the hinge cover on top of the freezer.
    • Pushing at the pointy part of the cover makes it easier to remove.
  4. Midea MRU03M2ABB Upright Freezer Door Replacement: 4 단계, 이미지 3개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 4 단계, 이미지 3개 중 2개 Midea MRU03M2ABB Upright Freezer Door Replacement: 4 단계, 이미지 3개 중 3개
    • Unscrew the hinge counterclockwise.
  5. Midea MRU03M2ABB Upright Freezer Door Replacement: 5 단계, 이미지 2개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the hinge out of the freezer and the door.
  6. Midea MRU03M2ABB Upright Freezer Door Replacement: 6 단계, 이미지 3개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 6 단계, 이미지 3개 중 2개 Midea MRU03M2ABB Upright Freezer Door Replacement: 6 단계, 이미지 3개 중 3개
    • With two hands, gently hold and open the door as usual.
    • Lift the door up to remove it from the bottom hinge.
    • You have completely detached the door from the freezer.
  7. Midea MRU03M2ABB Upright Freezer Door Replacement: 7 단계, 이미지 3개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 7 단계, 이미지 3개 중 2개 Midea MRU03M2ABB Upright Freezer Door Replacement: 7 단계, 이미지 3개 중 3개
    • With the new door, locate the hole underneath the door.
    • Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
    • Close the door.
  8. Midea MRU03M2ABB Upright Freezer Door Replacement: 8 단계, 이미지 3개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 8 단계, 이미지 3개 중 2개 Midea MRU03M2ABB Upright Freezer Door Replacement: 8 단계, 이미지 3개 중 3개
    • Use your hand to align the door so these three screw holes stay on the same line.
    • Carefully place the top hinge to fit these holes.
  9. Midea MRU03M2ABB Upright Freezer Door Replacement: 9 단계, 이미지 2개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 9 단계, 이미지 2개 중 2개
    • Thread and tighten the screws clockwise.
    • Gently swing the door to make sure it operates well.
  10. Midea MRU03M2ABB Upright Freezer Door Replacement: 11 단계, 이미지 2개 중 1개 Midea MRU03M2ABB Upright Freezer Door Replacement: 11 단계, 이미지 2개 중 2개
    • Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
    • A "click" will indicate that the cover is finally in its place.
결승점
작성자
2다른 기여자 명과 함께
Thinh Lang
회원 가입일: 01/16/24
193 평판
안내서 1개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 43
전체 시간: 911
